5vdc Power Supply for Ancillary Equipment
0 Members and 1 Guest are viewing this topic. Read 2527 times.
setamp
« on: 30 Jan 2012, 09:53 pm »
I am trying to find a good (and cheap?) solution to switching power supplies.  I am running an Oyen external HDD and a wireless bridge off of what I am sure are cheap, noisy switching power supplies.  What can I use to eliminate them?
It would be nice to have 1 unit with 2x 5vdc outputs.  I would consider diy if there are plans available.  I would also consider battery if that makes sense.
jtwrace
    • TIPP YouTube Channel
« Last Edit: 30 Jan 2012, 11:50 pm by jtwrace »
kenreau
Re: 5vdc Power Supply for Ancillary Equipment
« Reply #2 on: 31 Jan 2012, 06:35 pm »
This was a recommendation from Wayne of Bolder on another thread.  From PartExpress, a compact sized regulated power multi-voltage power supply ideal for all devices drawing up to 2 amps of current.  For $20, this is what I plan to use for my Oyen external HD
http://www.audiocircle.com/index.php?topic=100632.0
Kenreau
« Last Edit: 1 Feb 2012, 06:45 am by kenreau »
konut
setamp
« Reply #4 on: 31 Jan 2012, 08:18 pm »
Great info guys.  Thanks.
Wayne1
« Reply #5 on: 31 Jan 2012, 09:57 pm »
This was a recommendation from Wayne of Boulder on another thread.  From PartExpress, a compact sized regulated power multi-voltage power supply ideal for all devices drawing up to 2 amps of current.  For $20, this is what I plan to use for my Oyen external HD
Kenreau
The Parts Express supply is not set up for 5 volts out of the box. It can be modded to output 5 volts.
I think the Jerome Industries 5 volt supply is the best deal for 5 volts at 2 amps.
You will have to change the DC power connector to fit your HDD.
kenreau
« Reply #6 on: 2 Feb 2012, 12:02 am »
Good to know, thanks Wayne.   :thumb:
setamp
« Reply #7 on: 2 Feb 2012, 09:45 pm »
Is the Jerome Ind 5v supply a good, quiet unit as well as being the best deal?  I don't mind spending more if I were to make a real difference.  If I can use the Jerome and not create noise within my system that would be great.
