Replacement for basic wall wart PS
0 Members and 1 Guest are viewing this topic. Read 1858 times.
firedog
« on: 17 Nov 2011, 09:29 am »
Hi-
Thinking of replacing standard WW Ps's that came with my router and external HD. The idea is that this might reduce noise going into my networked audio system.
The PS's are both 12v; one is 1.5A, the other is 1A.
I'm not looking for something that costs hundreds of dollars. Tens of dollars - okay. I'm not even sure this will make any difference. Just thought it was worth a try if the experiment isn't too expensive.
Any suggestions for something that might be a quieter replacement for these WW PS's?
thanks
Wayne1
Re: Replacement for basic wall wart PS
« Reply #2 on: 17 Nov 2011, 04:01 pm »
A couple of the Parts Express power supply should be able to do the job
Parts Express 2 amp supply
$20.00
