0 Members and 1 Guest are viewing this topic. Read 6626 times.
How big is your room? The room will literally destroy a subwoofer's in-room response (output) if it isn't placed properly or if the subwoofer is too small for the cu. ft. of said room. Can you provide your room dimensions (L x W x H)? Before pulling the trigger you (we) need to make sure you're purchasing enough subwoofer for your room.Nuance, the room is divided by small partition. The listening area part is 10ft wide by 20ft deep x 10ft high. The total room size including the room on the other side of partition is more like 25ft wide x 20f deep x 10-14 ft high ( the ceiling height in the other side of listening area is 14ft). So it,s hard to say whether to measure the listening area only or the total space, esp since the partition is partial. Does this make sense? It,s an odd space.ThanksTom
