0 Members and 1 Guest are viewing this topic. Read 3200 times.
Cross talk = bleed through (that shouldn't have changed with time IMHO)
I did a DIY trick I read here on AC and made RCA shorts as a hum got so bad I couldnt stand it. I first found that one input needed to be unplugged and that took care of most of it. IT was getting loose in the chassis. The shorts on the inputs helped too. I'll resolder and replace all of the questionable RCA's once my Warpspeed comes and i can take it offline for awhile.Anyone know if Radio Shack phono plugs are as good as anything else for equal money or have a source for good inexpensive jacks? RS gets expensive, but is convenient (a mile from my house).Thanks all for the help,Ray
I actually shorted them a little differently. I just stripped the inner and outer wires on ancient RCA cables, twisted them and electrical taped them in a loop. Not as elegant, but effective. I mean no cross talk at all.Ive done too many other things earlier today to know if there were sonic benefits and i am in quiet listening mode right now too, but I will say I took the rubber mat off my TT, put on felt discs of varying size on the outer 2/3 of the platter and I swear bass, imaging, definition all went up in a big way. My little Paradigm Titans sounded like I hooked up a small sub. I used as few discs as I thought I could. Disc does not hit uniformly, but I think this is ok. Only problem is cleaning discs now is hard. The open space makes the disc wobble.I mean for sure it sounds better as the sound floor went to near nothing compared to before, especially as quiet as I am listening to now.
