Other Stuff
Archived Manufacturer Circles
Herbie's Audio Lab
Isolation feet for Meridian AD88
0 Members and 1 Guest are viewing this topic. Read 2747 times.
jostber
27 Jan 2012, 07:39 pm »
I have a Meridian AD88 standing on a small table. This unit has a downfiring woofer. Should I put some kind of isolation under the AD88 or the table legs?
Herbie
Industry Contributor
Re: Isolation feet for Meridian AD88
27 Jan 2012, 08:12 pm »
Primarily, under the AD88; secondarily, under the table legs. Ideally perhaps, both.
Herbie's Audio Lab
jostber
Reply #2 on:
27 Jan 2012, 08:52 pm »
What kind of feet or bases would you recommend under the AD88?
Herbie
Reply #3 on:
27 Jan 2012, 09:46 pm »
Herbie's Audio Lab has several products that should do very well under the Meridian AD88: Tenderfoot isolation feet, Extra-Thick
grungebuster
Dots, Square Fat Dots, Soft Fat Dots. I think four Soft Fat Disks would best address all the parameters involved with your situation.
Soft Fat Disks
Herbie's Audio Lab
Other Stuff
Herbie's Audio Lab
