0 Members and 1 Guest are viewing this topic. Read 8287 times.
Sounds like you guys had a nice time. Fwiw, don't wait for a simplified version from BSG anytime soon. They made it very clear (at THE SHOW) that they want to license the technology, not manufacture the product. I guess as soon as a pro audio or high end audio company picks it up is when you will see the next version of QOL. Otherwise it will be on a laptop or Nintendo DS or a cell phone.Interesting comments about the bypass guys. I hadn't thought of that when I heard it. (different circumstances too)
yeah if they can put it in a cellphone we outta get a less expensive box for our systems. Interesting that you had slightly different impressions though.
Regarding record noise, here are some footnotes from the owner's manual:2. The q∅lTM Signal Completion Stage works with Line-Level Inputs only. If you play records, use the output from your phono stage, not from your tone arm. With records that are in poor condition, you may want to use the Bypass feature of your q∅lTM Signal Completion Stage (see Bypass, p. 9). q∅lTM Signal Completion Stage technology brings out everything and poor surfaces may include noises you do not want to hear.3. If you listen to vinyl, depending on your cartridge and tone arm, the additional information may result in more sibilance or “crunch” than you heard before. Some adjustment of VTA (Vertical Tracking Angle) or VTF (Vertical Tracking Force) may be worthwhile.
What day?
