Trouble Removing the Avastar Cover
0 Members and 1 Guest are viewing this topic. Read 1617 times.
trackball02
« on: 27 Jan 2012, 05:03 am »
I'm interested in trying tube rolling; however, after removing the 6 top screws and the 4 side screws off the top cover, the cover still seems to be suck on. What's the next step that I need to do?  Thanks.
JerryM
  • Where's The Bar?
Re: Trouble Removing the Avastar Cover
« Reply #1 on: 27 Jan 2012, 05:14 am »
I have a T8, not an Avastar, but I'm guessing they are similar.
If you have removed four side screws, you have two more to go - one on each side.
Look on the sides; just under the seam between the top cover and the bottom, right in the very center, there is one screw on each side. Remove those, and you'll be rollin'.  :thumb:
Have fun,
Jerry
trackball02
« Reply #2 on: 27 Jan 2012, 05:50 am »
Jerry,
Thanks, it came right off. Now I'm rolling!
Jay
JerryM
  • Where's The Bar?
« Reply #3 on: 27 Jan 2012, 06:09 am »
Now I'm rolling!
Sweet!
Let those new valves get 100 hours or so on 'em before you pass judgement.  :thumb:
Have fun,
Jerry
trackball02
« Reply #4 on: 27 Jan 2012, 06:21 am »
I installed NOS GE tubes. They sound great so far.
