Bryston B60 SST and Dynaudio 4 ohm speakers?
0 Members and 1 Guest are viewing this topic. Read 3004 times.
Heckler75
« on: 27 Jan 2012, 01:12 am »
looking to add   a Bryston B60 SST  (int-amp)  with a   pair  of Dynaudio Focus 110, in my home office.
Dynaudio Focus 110   rated at  86dB  (4ohm)  bookshelf speaker
will   the B60 SST , be ok to use  with this speaker?
setup  is   for a  home office  15 x 14  room  and   mostly will   be "moderate listening"   no   ear bleeding  volumes.
really like the size, and specs of the 60b SST  :thumb:
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston B60 SST and Dynaudio 4 ohm speakers?
« Reply #1 on: 27 Jan 2012, 01:45 am »
Hi heckler
Taking into account room size, speaker efficiency and normal listening levels yes you will be fine. :thumb:
james
rhart
« Reply #2 on: 27 Jan 2012, 02:01 am »
I've tried my B60SST with Dynaudio. No problems, even in a larger room.
Stu Pitt
« Reply #3 on: 27 Jan 2012, 02:03 am »
I've heard the combination.  It sounds very good IMO.  As James said, so long as you're staying in the parameters you mentioned, you shouldn't have any issues.  Those were the condition I heard the combo under, more or less.
Heckler75
« Reply #4 on: 27 Jan 2012, 03:22 am »
Hi heckler
james
Hi  James,
Sweet :thumb:
can't   wait  till  my BDP-1  arrives, will  complete  my  living room setup   4BSST2/BP26/BDA-1   and   soon   the BDP-1  :P
Bryston, makes truly  elite  products. IMHO
lanchile
« Reply #5 on: 27 Jan 2012, 06:23 am »
Bryston B60 is an awesome machine :thumb:, it will play hotter at 4 ohms than at 8 ohms.
I had a B60, it runed some how a little hot at 6 ohms but the sound was wonderful.
if I had to change something about the B60, I would just change the small heat sinks for bigger and outside ones. I know it will be bigger and more expensive, but it will run cooler and that means....instead the 20 years warranty, you will have a 60 years warranty lol.
Bryston B60 is on top of my list of the best integrated amp under 100 watts RMS per channel period!!!
