A little question .
0 Members and 1 Guest are viewing this topic. Read 2979 times.
joaco_
A little question .
« on: 26 Jan 2012, 02:33 am »
Hello all  :D
Im using a tap-x with the s&b trafos , as I didnt find this answer nor the manual im asking for a little help . Can someone please give me an idea of how the switch that is marked H and F works please .
Thanks .
John Chapman
    • http://www.bentaudio.com
Re: A little question .
« Reply #1 on: 9 Feb 2012, 10:07 pm »
Hello!
Very sorry for the late reply.... I really have to check in here more often!
These select the connection of ground to from the input (source) side to the output (amp) side of the pre-amp.
'F' is Float mode - no connection from input to output
'H' Is Hard Ground mode - the input ground is connected to the output ground.
Which to use is totally system dependant - there is no right or wrong or better way to set it. If your system is quiet then that is the right setting. Some systems do not care at all and are quiet in either mode. Some are a bit quieter in one or the other and once and a while a system really needs to be set one way or another.
Thansk!
John
« Last Edit: 20 Feb 2012, 08:47 pm by John Chapman »
joaco_
« Reply #2 on: 19 Feb 2012, 05:31 pm »
Thanks for your time john .
