Is the Dodd buffer in the ICE amps the same as the Sensations?
0 Members and 1 Guest are viewing this topic. Read 1766 times.
Trismos
Forgive me if I seem to be beating on this damn horse but I read this thread http://www.audiocircle.com/index.php?topic=100108.0 in relation to a tube problem I seem to be having, which led me to this thread: http://www.audiocircle.com/index.php?topic=79449.msg757037#msg757037 which gives me a long list of Dodd approved tubes for the buffer. This particular thread is for the ICE amps but I've been told the buffer is the same - at least in regards to the tubes you can roll. True? If so, why won't the Psvane 12AU7-Ts I ordered work with my amp. In this thread: http://www.audiocircle.com/index.php?topic=101822.20 our good man brother love indicates he has a set-up almost identical to mine. He reports having good results with this tube.
Ian from Grant Fidelity says he would not recommend this tube as a replacement, let alone an upgrade. What gives?
Just for funzies, or because someone might see something obvious, here's my simple system: Grant Fidelity RPF-120 MKII Reference Power Conditioner, XPC Shuttle Music Server, Centrance DACmini CX, Virtue M-901 with Clarity MRs and Dodd buffer on 24v 28ah batteries and Soneil charging system, GR N3s. All the wires, from the USB to the speakers are of at least descent quality (The USB is a Cardas Clear, and that's probably about the average of what I have in quality for each piece).
Anyone?
Regards
Dave
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
The buffer is the same, tubes should roll fine if Gary specified them.
