0 Members and 1 Guest are viewing this topic. Read 9221 times.
Jim,Are the dimensions the same as the Song Towers, or did Paul have to redesign the cabinet for the new drivers?Thanks,Ron
Paul - You are correct. The ST-SC cabinets are not as deep as the original SongTower cabinets. The terminus was re-configured as well.- Jim
So Jim or Paul could you explain how the SC-ST compares to the HT2-TL? I have ST's w/ow2's and have been leaning towards upgrading to HT2-TL's but if the SC-ST has a very similar sound I may be interested as space is something I'm taking into consideration, ( I'm keeping my ST's in the system ).
Yep, I did go back and check. I reduced the internal depth by 2", tweaked the port's dimensions and location, and modified the stuffing density. Ended up with a modeled anechoic F3 of ~34 Hz versus ~42 Hz for the STs. Very pleased with the results.Paul
does the full length baffle add another 3/4" or 1" to the depth though?
Would I be crazy considering replacing my HT2-TLs with the SC-ST? I don't need the increased bass abilities of the HT2-TL since I always use a sub.
Kind of crazy. Do your HT2-TL's have the LCY ribbon tweeter? If so, perhaps it makes some sense.- Jim
Mine have the RAAL tweeter.Crazy as charged?
I'll trade you my SongTower's for your HT2-TL's, and then your space issues will be solved.
