Review of AVA's New 400R amp, FET Valve Pre and DAC
0 Members and 1 Guest are viewing this topic. Read 1712 times.
I.Greyhound Fan
« on: 25 Jan 2012, 03:16 am »
Ok,  here is my reivew of the New 400R, Fet Valve Preamp and Fet Valve DAC-
I posted it in the Multi Category Review section of this forum.  Here is the link-
http://www.audiocircle.com/index.php?topic=102855.new#new
Tom Alverson
Re: Review of AVA's New 400R amp, FET Valve Pre and DAC
« Reply #1 on: 25 Jan 2012, 03:55 am »
Thanks for posting the review.  If you could only afford to upgrade one of the three right now, which would it be?
Tom
Vison Preamp/DAC + 600R
I.Greyhound Fan
« Reply #2 on: 25 Jan 2012, 04:36 am »
Tom
Tom,
I would definitely go with the 600R.  The amp made the biggest impact.  You get the speed, bass, depth, transparency, detail and wide sound stage.  I would upgrade the preamp next and then the DAC.  But all three have this great synergy together.
Here is the review I did on the 600R a while back-
http://www.audiocircle.com/index.php?topic=97775.msg981051#msg981051
Larry
