FS: NHT X2 active crossover
0 Members and 1 Guest are viewing this topic. Read 1497 times.
Nietzschelover
« on: 24 Jan 2012, 06:17 pm »
Asking $225.00 for an NHT X2 active electronic crossover.
It is in mint condition.
Stereo, or mono, operation; RCA and XLR inputs and outputs.
Pictures available.
Specs below:
Frequency response: 15Hz - 220Hz +/-3dB
through L/R input (continuously variable)
15 - 220Hz +/-3dB through LFE input (fixed)
50, 80, 110Hz-100KHz +/-3dB
Distortion: < 0.01% subwoofer output @ 100Hz, 1V
< 0.001% hi-pass output @ 1KHz, 1V
Signal to noise ratio: >105dB at Hi-pass output
>100dB at subwoofer output
Crossover: Low-pass continuously variable between 30-220Hz, 12dB/octave
Low-pass fixed at 220Hz,12dB/octave
High-pass selectable between 50, 80, 110Hz, 12dB/octave
Input connectors:
Gold plated RCA jacks for L and R line level input
XLR jacks for L and R line level input
Gold plated RCA jack for LFE input
XLR jack for LFE input
Detachable terminal block for external trigger in/thru
2.1mm x 5.5mm x 9.5mm power connector
Output connectors:
Gold plated RCA jacks for L and R line level high-pass output
Gold plated RCA jack for LFE thru
XLR jacks for L and R line level high-pass output
Gold plated RCA jacks for L and R line level sub woofer output
XLR jacks for L and R line level subwoofer output
Phase Control:
Variable between 0 and 90 degrees
Switchable 0 - 180 degrees
Gain Control: +10dB and 0dB subwoofer input sensitivity
Stereo / Mono Switch: Stereo or mono subwoofer operation
Standby Mode: Selectable internal and external. External 5 -24 VDC
Internal automatic when no signal is present for >20 minutes
Power Consumption: 3W
Weight: 9 lbs.
Dimensions: 1.5"H x 17"W x 11.5"D
Finish: matte black anodized front panel, black painted chassis[/size][/size]
« Last Edit: 25 Jan 2012, 06:16 pm by Nietzschelover »
Nietzschelover
Re: FS: NHT X2 active crossover
« Reply #1 on: 25 Jan 2012, 06:17 pm »
Sold.
