FS: VH AUdio (VenHaus) Hot Box with 6 Foot PC-PRICE DROP $150
0 Members and 1 Guest are viewing this topic. Read 1482 times.
kbuzz3
Ive moved and im forced to sell parts of my system and second system to consolidate.  As part of that sale i am offering a Chris VenHaus Hot box in excellent condition.  This model has a 6 foot Ven Haus Power Cord, itself a great performer. It also does have the small amount of filtration offered by Venhaus Audio.  New its north of $400 so im thinking about $200.  The stock photo is available here:
http://www.vhaudio.com/images/vhhotbox.jpg
More information on the unit is available athttp://www.vhaudio.com/hotbox.html
Details from the site are copied below. I can send actual pics of the unit if you are interested.
Features of this design include:
* Star wiring to each receptacle. (The receptacles aren't "daisy-chained" together).
* A modified Flavor 4 cord connected to the outlet box. Two separate 10 AWG Teflon/Bare copper ground wires are spaced from each other as they spiral around the outside of the cable, counter to the twist of the internal conductors.
* The cryoe'd outlets are electrically isolated from the metal box. One of the ground wires is connected to the outlets' grounds (in a star wire fashion), and the other ground is connected to the box. Most manufacturers "float" the metal box or they ground the outlet to the box. Steel has excellent permeability of magnetic fields- so it is a good thing to have steel for box construction.
* All internal wiring is SPACED AWAY from the box itself, in order to keep the interactions of the conductors with metal box to a minimum.
* The Hot Box contains NO field-generating LED's, poor switches, or IEC inlets. Just raw power delivered to your components without adding any grunge...
* Your choice of 15 or 20 amp Deep Cryogenically treated Pass & Seymour receptacles (5262AI or 5362AI) are standard
* Also available with optional AC receptacles and male plugs from P&S and Furutech.
* An optional power filter upgrade may be purchased for an additional $99.99. Simply order the Hot Box, and then order the filter upgrade for $99.99.
Like all VH Audio wire and cables, this product was developed by Chris VenHaus after extensive listening tests over a period of several years, and is ONLY available at VH Audio. As with all VH Audio wire and cable, this product has been manufactured to VH Audio's specs in the USA, and is only available at VH Audio.
I will be offering some more items this week including a heavily modded bolder cables SB3, Trends audio 10.1 and various cables
« Last Edit: 31 Jan 2012, 04:27 pm by kbuzz3 »
kbuzz3
Price drop
« Reply #1 on: 26 Jan 2012, 02:49 pm »
Price drop to $150
« Last Edit: 31 Jan 2012, 04:28 pm by kbuzz3 »
