Looking for very small "bookshelf"
0 Members and 1 Guest are viewing this topic. Read 8268 times.
JohnR
milford3
Re: Looking for very small "bookshelf"
« Reply #21 on: 24 Jan 2012, 11:32 pm »
I have the M2v3 in my bedroom
http://www.axiomaudio.com/m2.html
sts9fan
« Reply #22 on: 25 Jan 2012, 01:17 am »
Make a pair!
http://www.madisoundspeakerstore.com/approx-3-fullrange/aurasound-ns3-193-4a-3-extended-range-4-ohm-silver-cone/
(For example  :D )
I have shame for not wanting to build a pair.  :cry:
That said I have a brand new pair of Mark Alpair 7.3 that I could use.
neekomax
« Reply #23 on: 25 Jan 2012, 01:36 am »
JohnR
« Reply #24 on: 25 Jan 2012, 01:47 am »
Well, that should certainly be an upgrade from my suggestion :)
I.Greyhound Fan
« Reply #25 on: 25 Jan 2012, 03:29 am »
I agree, NHT's.  But also consider PSB B4's, Monitor Audio's  M series , PSB Alpha B1's, Paradigm Atoms, B&W 686's.  If you want to go budget, consider infinty Primus 152's, stereophile gave then a good write up a few years ago.
http://www.stereophile.com/budgetcomponents/404infinity/
here's a review on the $250pr PSB Alpha B1's-
http://www.stereophile.com/standloudspeakers/580
« Reply #26 on: 25 Jan 2012, 10:40 am »
Gallo Micro or A'Diva?  (roundsound.com)  Colorful/round, great for baby.
TBI Majestic Diamond I or IR  (tbisound.com)  Maker of those amazing/compact subs.
All are at or under $600/pair.  All are under 6 inches across.  All wall mountable.  All placement friendly (even bookshelfs).  Bass response rated as low as 40 Hz.
mrhyfy
« Reply #27 on: 25 Jan 2012, 11:43 am »
These Swans are very nice. I have the D2.1  se+ and love them.
http://www.theaudioinsider.com/product_info.php?p=swan-d1-1se&products_id=140
wharfrat
« Reply #28 on: 25 Jan 2012, 12:00 pm »
Sts9fan- I sent you a PM.
sts9fan
« Reply #29 on: 29 Jan 2012, 06:52 pm »
I listened to the PSB Mini yesterday. They are very good!!
sts9fan
« Reply #30 on: 3 Feb 2012, 12:03 am »
I ended up buying a pair of the Paradigm Millenia One.
The are solidly built come with mounting hardware. They sounded quite good mounted on walls at the shop.
