0 Members and 1 Guest are viewing this topic. Read 12803 times.
1. Do I need to buy a pre-amp to use with the turntable, or will the Jolida Tube Amp act as a pre-amp?
4. If I decide to add a CD player later on, will that also work with the Tube amp or will I need to buy a receiver?
The path of vinyl is not for the faint of heart. There are more than one threads here that chart peoples vinyl angst. I believe there are many steps to vinyl life. First thing is you are going to need local support. Find some local vinyl boys that are experienced and hopefully have good sounding systems. Any vinyl guy who has been around a while not only has all the tools but has extra decks and carts and Phono stages.It is really easy to spend money and not improve your playback chain.I would probably start out with a TCG dd jvc and do the cheapo tricks. Now you can focus on cleaning and preparing your vinyl. A good cleaning set up is requisite. This is another area your local heroes can assist you.I could not have risen out of the primordial vinyl soup without a group of vinyl fanatics to steer me through my set up and purchasing.Phone stages, tonearms, cartridges, and tts are so system dependent it is difficult to make blanket suggestions. The analog playback system is a system and the best thing to share is to remember it functions as an organic system.Good luck and if you are in the bay area I would be happy to help.
