Wood or Aluminum? and why?
0 Members and 1 Guest are viewing this topic. Read 2934 times.
Indiansprings
« on: 23 Jan 2012, 08:54 pm »
I am looking to rid my Denon 103R cartridge of its plastic body. There are nice wood ones from Aussie and some nice looking Aluminum ones from the UK. Wood is more cash but that is not a factor so don't use that as an excuse. Be sure to tell me your thoughts. It would be nice to have hands on experience.
Wood http://www.ebay.com/itm/250842975115?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Aluminum http://www.ebay.com/itm/320831558314?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
blakep
Re: Wood or Aluminum? and why?
« Reply #1 on: 23 Jan 2012, 10:23 pm »
In another month or two I'd be able to give you a definitive answer as I have a 103R in an aluminum body coming back from Soundsmith. I've used 103R's in wood bodies (ebony and clavellin) for about 4 years; my current cartridge is a 103R with a $250 Soundsmith retip in a Uwe ebony body.
Bear in mind that even the different woods have different sonic signatures. For example, I much prefer the ebony to the clavellin which seemed to be quite a bit harder sounding and a bit tipped up with a less powerful bass than the ebony. Tighter perhaps, but less powerful. But system synergy and subjective listener preferences are at work with all this stuff and what I prefer may be the opposite of what you are looking for.
I never used the aluminum body before transplanting a 103R into it shipping it off to Peter Ledermann but I would expect the aluminum body, when it comes back to do some things better (again, subjectively) than the ebony while perhaps exhibiting some less likeable characteristics. My guess is that the aluminum will be very explosive and dynamic, more so than the ebony, but perhaps be a little harder and more analytical sounding as well.
My current cartridge leads (on the ebony bodied, SS retipped 103R) are silver and, generally speaking, I am not a fan of silver-don't have it anywhere else in the system. My plans, when the aluminum body comes back, is to switch over to copper cartridge leads to offset some of the hardness that I think the aluminum will bring to the table relative to the ebony.
Either one, aluminum or wood, will be a huge improvement over the stock plastic body, and combined with a retip with a good stylus like Soundsmith's the cartridge becomes a giant killer. For either cartridge (aluminum or wood body) to fully realize its potential, though, it will need a high mass arm. With the aluminum body, which is heavier, you need to get into the 20-22 gram effective mass area. The wood bodies are a bit lighter but still quite a bit heavier than the stock plastic shell; with those you need to get into the 24-25 gram effective mass area for the cartridge to really shine.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 24 Jan 2012, 01:23 am »
great thread!   :thumb:
roscoeiii
« Reply #3 on: 24 Jan 2012, 02:04 am »
Might want to look into this over on Audio Asylum or Vinyl Engine too. A good deal of Denon posts and threads IIRC.
blakep
« Reply #4 on: 18 Feb 2012, 08:21 pm »
The aluminum body is up and running. For a comparison with the Ebony Uwe body (well almost-nothing is that simple :lol:) my impressions are here:
http://www.canuckaudiomart.com/forum/viewtopic.php?t=23543
lextek
« Reply #5 on: 25 Feb 2012, 02:43 pm »
So I've rethought the USB route.  Now I'm looking at two entry level tables.  The Music Hall mmf 2.2 or Pro-Ject Debut III.  Then some type of phonopre with USB.  Only reason for the USB is because my wife has some albums you would like in digital format.
Sorry some how ended up in the wrong circle
Indiansprings
« Reply #6 on: 25 Feb 2012, 02:57 pm »
...and? Your going to use a Wood bodied cart or Alum?  :scratch:
You might have poster this in the wrong thread.
lextek
« Reply #7 on: 25 Feb 2012, 03:34 pm »
Yup.  Don't know how I ended up here.....
