Help identifying capacitor
0 Members and 1 Guest are viewing this topic. Read 2889 times.
santacore
« on: 23 Jan 2012, 08:15 pm »
I'm hoping someone can help me identify and source a set of caps that are bulging in my Audio Research amp. I'm planning to have a tech install these, but want to have the parts on hand when I'm ready. Any help with finding these would be appreciated. Thanks!
jtwrace
    • TIPP YouTube Channel
Re: Help identifying capacitor
« Reply #1 on: 23 Jan 2012, 08:19 pm »
Digikey has them.
Speedskater
  • Kevin
« Reply #2 on: 23 Jan 2012, 08:20 pm »
In the US, you might try:
http://www.mouser.com/nichicon/
avahifi
    • http://www.avahifi.com
« Reply #3 on: 23 Jan 2012, 08:30 pm »
These all appear to be 15,000 microfarad, 50V electrolytic capacitors, of the "snap in" construction type.
Replacements will be available at Digi-Key or Mouser, etc.  In ordering replacements, first measure to determine the diameter and height of the existing parts.  Look carefully at the specifications of the ones you order to make sure they are within the dimension limitations of the originals or the replacements will not fit on your circuit board.  Any good industrial brand will be fine, Panasonic, Nichicom, Chemicon, etc.  These are just being used for some raw power supply application and musical quality will not be an issue.
I should note that the minor top of case bulging is not abnormal for this kind of capacitor after long use in a hot environment.  Unless you know they are defective, I would not recommend replacing them as you will have to remove the circuit board to do that and the chances of doing accidental damage could be high.  Leave a sleeping dog alone unless it is barking at you.  When these fail, the unit will bark at you for sure.
Given this configuration of eight of these capacitors and their rather low voltage rating, I suspect they are likely paralleled together to provide a huge low voltage supply in your unit, maybe a tube heater or solid state supply of some sort, certainly not for high voltage vacuum tube B+.
Best regards,
Frank Van Alsitne
santacore
« Reply #4 on: 24 Jan 2012, 04:48 am »
Thanks to everyone for the input, especially Frank!
The amp is a solid state Audio Research and recently started blowing fuses on start up. When I opened it up I immediately noticed what I believe are power supply caps that were bulging. I was hoping to save some time by sourcing the caps myself, so that when I could take it to a tech it would be smoother process.
I guess the bottom line is I should just take the time and money to send it back to A.R. for proper repair. Thank you again for the help!
*Scotty*
« Reply #5 on: 24 Jan 2012, 05:42 am »
I've got to second your motion for sending it back to Audio Research. It will come back good as new and they stand behind their work.
Scotty
