0 Members and 1 Guest are viewing this topic. Read 18739 times.
From Mundorf capacitor datasheet. Replacing steel with copper conductors WILL make an audible difference! No steelFrom now on, steel connectors are a thing of the past at MUNDORF because the use of steel as material for connectors[word-wide standard for snap-ins] has many disadvantages: Among other things, steel connectors cause unwanted eddycurrents due to their magnetic properties, have a poor electric conductivity [σ25°C 6.2MS/m = 10.7% IACS = 160mΩ*mm2/m] and a low thermal conductivity [λ25°C 50W/(m*K)]. In addition, the high elasticity [200 GPa] and hardness [7 Mohs] ofsteel snap-in clamps are a permanent stress for the soldering joint which might reduce the quality of the joint.
Dave, none of that means that you'll be able to hear the steel connectors that Magnepan uses. There simply isn't any engineering reason why you would. The eddy currents don't matter, the conductivity doesn't matter, and the hardness doesn't matter in that application.
Which binding posts will fit without drilling out the existing plates?
Am considering new binding posts for my 3.7 maggies. Can quality after-market binding posts improve the sound over the cheesy steel thingy that Magnepan uses.
Aesthetics aside, can you honestly say that there's any improvement in the sound quality from that?
