Pure Music 1.85
0 Members and 1 Guest are viewing this topic. Read 1951 times.
jtwrace
    • TIPP YouTube Channel
Pure Music 1.85
« on: 21 Jan 2012, 02:24 am »
Download it here.  http://www.channld.com/download.html
1.85
• Eliminated unexpected quit when loading extremely large files into memory
• New “Hide All” command hides the Pure Music and iTunes applications
• New preference setting that allows changing the button font to Helvetica, for computers on which the Arial font is missing or unavailable
• Corrected issue introduced in 1.84 where adding FLACs when bookmarks previously existed would unnecessarily copy artwork again
• Corrected issue introduced in 1.84 where converting FLACs to Apple Lossless would extract the artwork as separate files
• Corrected issue introduced in 1.83 where playing 88.2 kHz tracks on a DAC that only supported 44.1 kHz would play the tracks at incorrect (slow) speed (tracks not downsampled)
• Corrected issue in Less is More Mode where trying to jump to a track in a different playlist (using skip ahead or play selected) had no effect
Crimson
Re: Pure Music 1.85
« Reply #1 on: 21 Jan 2012, 05:02 am »
Thanks for the heads up. I'm still on 1.82. Tried 1.84 and wasn't thrilled. Will probably wait for 1.86.
jtwrace
Re: Pure Music 1.85
« Reply #2 on: 21 Jan 2012, 10:37 am »
Wow.  What do you not like in the newer versions?
Crimson
Re: Pure Music 1.85
« Reply #3 on: 21 Jan 2012, 11:14 am »
Brittle sounding. I used to like it, but since Amarra 2.3 I've pretty much switched.
