What preamps have no, or very little gain?
0 Members and 1 Guest are viewing this topic. Read 1969 times.
Hantra
« on: 7 May 2004, 12:42 am »
All:
I would like to have a remote controlled pre that kicks ass, is not too expensive, and has no gain.  I was thinking of a Bent, but do they add warmth?  I have enough warmh as it is, I just want a more linear pre.  I could go active if I could find one with just a minute amount of gain.
B
mgalusha
« Reply #1 on: 7 May 2004, 12:46 am »
You might take a look at the Placette remote volume control. It's a passive using Vishay resistors and is supposedly very clean. I havn't heard one but do know a gentlemen who owns one and is very happy with the performance. Not inexpensive at $1K tho.
mike
Marbles
« Reply #2 on: 7 May 2004, 01:23 am »
No added ANYTHING on the silver tranny Bent...it is like No(h) pre-amp at all, except for volume control and source switching.
Highly recommended
dado5
« Reply #3 on: 7 May 2004, 01:35 am »
Here is the only unity gain active preamp offered for regular sale that I know of:
http://www.decware.com/linestage/zp1.htm
Here are some low gain units:
http://hollowstate.netfirms.com/line2.htm
http://www.transcendentsound.com/preamp%20kit.htm
Your options expand with DIY:
www.diycable.com  look for  the DACT active units. The pre amp is configurable for 0/6/9 dB gain.
www.welbornelabs.com   look at the site map for his projects catalog (not his kit or parts catalogs)  in it he has a buffer amp that can be configured as a zero gain pre.  Claims it sounds better than Corey Greenberg's
famous Stereophile design.
http://hometown.aol.com/kevinc927/myhomepage/linestage.html  a pricey kit that uses highly regarded iron.  Probably the lowest gain for a tube stage you are likely to find.
Happy hunting,
Rob
[/url]
dvb
« Reply #4 on: 7 May 2004, 03:15 am »
Not sure of your budget, but FT Audio now has a remote option for their "little wonder"  Probably about $600
zybar
« Reply #5 on: 7 May 2004, 03:34 am »
I own the Placette and it is quite good.
I am selling it though because I want a balanced preamp and more than a single input/output.
If you are interested, let me know.
Regardless, I don't think you can wrong with either the Placette or Bent preamps.
George
dado5
« Reply #6 on: 8 May 2004, 08:33 pm »
Dude I am sorry!
I just re-read your post and noticed I missed you were looking for remote controlled pre amps!
If you are inclined towards DIY,  here is a remote volume control that can be inserted into any one of the projects I listed in my first reply.
http://www.audioelectronicsupply.com/cgi/view_services.cgi?request=detail&dept_id=15&aisle_id=156&prod_num=POT_ALP_RVC_2_KIT
Rob
« Reply #7 on: 9 May 2004, 11:57 am »
I've heard the Decware and the Transcendant.  The Decware is neutral (I couldn't hear it adding/subtracting anything from the music).
The Transcendant seemed to add gain, bass, and warmth.  Doesn't seem to be what you need.
