setup question vr5
0 Members and 1 Guest are viewing this topic. Read 1115 times.
duguyisheng
setup question vr5
« on: 19 Jan 2012, 05:23 am »
SETUP QUESTION
I have a setup question for the VR-5 Anniv.
As I understand it for most speakers, the center of the tweeters should aim about 1-2 inches above the ears from the favorite listening position. Is this true of the Vr-5 and if so, do you measure from the tweeter or the mid-range??
JackD201
Re: setup question vr5
« Reply #1 on: 19 Jan 2012, 05:30 am »
Hi,
Typically I like height to be between the center of the tweeter and that of the midrange in a quasi-pointsource like VR-5s. Having said that, the wide and even off axis response of the VRs both vertically and horizontally make relative height not much of a concern. I think whatever looks most comfortable to you from the listening position should do the trick. Balance hardly changes over a few inches of difference in seated height. Enjoy!
es347
  • ..I've got my eye on you...which one you say?
« Reply #2 on: 19 Jan 2012, 02:30 pm »
I agree with Jack.  I have done the up and down thing with my Annies and the difference if there is one is subtle.
