Stepped Attenuator for a 24v Aikido?
0 Members and 1 Guest are viewing this topic. Read 1160 times.
JDUBS
« on: 18 Jan 2012, 03:05 am »
Hey Guys
What value stepped attenuator should I use for my 24v Aikido preamp?  I'm thinking about adding some gain to my F3 (it only has 12.5db of gain) so I can better match it with the other two amps in my 3-way active setup.  The F3 has only 10k input impedance.
I was cruising ebay and there seems to be some pretty good attenuator deals out of Hong Kong.
I'm trying to sell the F3 and the Aikido, but if I can make the combo work in my setup, I might just keep them both.
Jim
JohnR
Re: Stepped Attenuator for a 24v Aikido?
« Reply #1 on: 18 Jan 2012, 03:18 am »
Anything from 10 to 100k should be fine. I'm assuming the attenuator will be on the input to the Aikido. I'm not entirely sure why you need it though.
JDUBS
« Reply #2 on: 18 Jan 2012, 03:24 am »
John
I believe the gain on the 24v Aikido is ~15db, no attenuator.  With the F3 at 12.5db, the combo would be a little "hot" relative to my other two amps.
I'd rather attenuate in the analog domain rather the digital, if possible.
Make sense?
Jim
