Large Mixed Group of 6SN7GT 6SN7GTA and 6SN7GTB Vacuum Tubes (29 Total But Read)
0 Members and 1 Guest are viewing this topic. Read 1368 times.
baileyler
$145 plus shipping (plus Paypal fee if using Paypal)
I am trying to clean out some of my various odds and ends, so this mixed group of various 6SN7GT, 6SN7GTA and 6SN7GTB vacuum tubes is up for sale.
There are 29 tubes in all, but a couple test low or have an issue (explained in detail below) so the number of useable tubes may be a few less.
Even the ones that tested low on the B&K did test into the “good” range on a reliable emissions tester (Precision 660), so they may still have some usefulness left.
My strong preference is to sell these as a group, but I may split up for the right offer.  I may also consider some trade value (see below).
A few of the tubes come with what appear to be original boxes but, for the purposes of this listing, all tubes should be considered used.
I only performed a basic screening of all the tubes on a reasonably calibrated B&K 700, where 65+ is in the green (‘good’), and I believe that 100 is supposed to be “average new” (but this can vary from tube to tube). The B&K meter does not have much definition, so the numbers are approximate.  All tubes were clean for shorts and leakage, except for one as indicated below.
The tubes and results are as follows.  The results are presented as (1) test results, (2) date code (where available) and (3) comments.
If needed to close a deal, I will be willing to run a couple of these tubes through my current best tester for small signal tubes - a Weston 981 III.
Sylvania 6SN7GT – Shorter Bottle, 3-Rivet T-Plate
88/86      352
Sylvania 6SN7GT – Mid-Sized Bottle, 3-Rivet T-Plate, Shorter Base
81/81      313
101/103                252
89/93      252
Sylvania JAN-CHS-6SN7GT VT-231 – Tall Bottle, 2-Rivet T-Plate
105/107         Has old residue of some sort all over it.
Sylvania JAN-CHS-6SN7GT – Shorter Bottle, Triangle Plates, Shorter Base
88/96      601
Sylvania 6SN7GT – Taller Bottle, 2-Rivet T-Plate
98/90      026      Comes with what appears to be original box
104/86                026
88/78      013
Weak                5039      Philco branded, tube looks physically good with only a small amount of deposit on glass, so I decided to include it.
Not Tested   126      Showed leakage on the B&K 700 but did not on a second tester (Precision 660) so I decided to include it.  Did not test further.
Teletone (National Union) 6SN7GT – Black Glass
40/40                50-22      Tests weak but there is no deposit on the top glass and physically looks like it has had little use, so I decided to include it.
Motorola (Tung-Sol) 6SN7GT – Taller Bottle, 2-Rivet T-Plate, Round Mica Supports
Weak                322107   Tests weak but physically looks like it has had little use, so I decided to include it.
Sylvania 6SN7GTA – Shorter Bottle, 3-Rivet T-Plate, Full Base
88/88      339
95/96      339
65/65      326
60/75      326
Sylvania 6SN7GTA – Shorter Bottle, Triangle Plate, Full Base
100/92                AC
Sylvania 6SN7GTA – Shorter Bottle, Triangle Plate, Shorter Base
92/92      452
GE 6SN7GTA – Horseshoe Side Getter
98/111                3-52
Chief 6SN7 – Believed 6SN7GTB, Tung-Sol Made, Tall Bottle, Brown Base, Triangle Plate, Horseshoe Getter
80/78      959 (32235908 etched in top glass)
Westinghouse 6SN7GTB – Tall Bottle, Flat Plates
97/97      7R43
Sylvania 6SN7GTB – Yellow Print, Triangle Plates
70/94      BH
GE 6SN7GTB – Side Halo Getter
87/89      JU
Sylvania 6SN7GTB – Coin Base
75/70      ab AFE
RCA 6SN7GTB – Coin Base
55/50         Comes with Original box, and looks to have had little use so I decided to include it.
Raytheon 6SN7GTB – Japanese Made, Tall Bottle, Flate Plates
97/87         Comes with Original Box
93/90         Comes with Original Box
70/74         Comes with Original Box
I can provide additional information or pictures upon request.
GENERAL TERMS AND CONDITIONS – PLEASE READ CAREFULLY
Please note that these tubes are being sold ‘AS IS’.
I ONLY describe what I know about the tubes, and what I have tested for.  Although my tube testers tend to be reliable, YOUR TUBE TESTER MAY GIVE A DIFFERENT RESULT THAN MINE, so please take that into account.  If the information is not there, DO NOT ASSUME, and do not rely on any of YOUR assumptions.  If you need more information than provided in the listing, ASK IN ADVANCE.  If I happen to have the information, I will provide it.  If I can get the information in a reasonable way, I will get it.  If I do not call a tube NOS, consider that tube used.  I do the best I can with very limited time and capabilities.  I am an honest seller, but I am NOT a tube professional, and I am NOT in the tube business.
AS SUCH, PLEASE NOTE THAT I CANNOT GUARANTEE (OR EVEN REMOTELY PREDICT) HOW THESE TUBES WILL SOUND OR PERFORM IN YOUR EQUIPMENT.  THE TEST RESULTS ARE ONLY PROVIDED AS AN INDICATION OF TUBE PERFORMANCE IN A VERY LIMITED (AND NON-IDEAL) ENVIRONMENT.  OTHER THAN AS SET FORTH ABOVE, I EXPRESSLY DISCLAIM ANY LIABILITY WITH RESPECT TO THESE TUBES OR RESPONSIBILITY FOR YOUR USE OF THEM.
Shipping in the USA will be via US Postal Priority Mail.  Insurance if desired will be extra.  I would estimate that the package weight will be about 3 lbs, but will charge no more than a large Flat Rate box to your location (or less if actual is less).  If you are outside the USA, or wish to use a different shipping method, contact me for a shipping quote.
Money order/cashiers check/personal check preferred, but all (other than US Postal money orders) must clear my bank first.
I also accept Paypal for convenience (but add 3% to the total for USA, and 4% to the total everywhere else).  IF YOU PAY VIA PAYPAL, HOWEVER, A CONDITION OF YOUR PAYMENT IS THAT YOU EXPRESSLY WAIVE THE RIGHT TO FILE A PAYPAL CLAIM OR CHARGE BACK (but do retain the right to sue me in court should you so desire).
I may consider some trade value, but my needs are few.  A couple of tubes interests include 45, 46, 47, 7591/7591A, KT90, M8162, CV4024, E81CC and ECC801s.
Please check my feedback on Audiogon, Videogon and Ebay (ID=baileyler) and buy with confidence.
