Converting the standard ST to ST ribbon
0 Members and 1 Guest are viewing this topic. Read 1443 times.
ricardojoa
« on: 17 Jan 2012, 11:26 pm »
Hi Jim, i was curious if would it be possible to convert the dome ST to the Ribbon raal tweeter?
Nuance
Re: Converting the standard ST to ST ribbon
« Reply #1 on: 17 Jan 2012, 11:58 pm »
New crossover, different sized mount hole for the driver (I think), etc.  I am sure Jim will chime in.  Worse case scenario, ask Jim to help you sell the dome versions and then put that towards the RAAL's.
charmerci
« Reply #2 on: 18 Jan 2012, 05:54 am »
This has been discussed here before. Basically, it's not worth the time delay and the fairly high cost of cutting and refitting said speaker with a new crossover for a minimal to somewhat improvement.
