SOLD: PolyCrystal ISO-3 Isolator Cones (Set of 3)
0 Members and 1 Guest are viewing this topic. Read 2536 times.
R Browne
« on: 17 Jan 2012, 12:13 am »
SOLD: One set of three PolyCrystal ISO-3 Isolator Cones in excellent condition.
Each PolyCrystal ISO-3 Isolator measures 1-13/64" in diameter by 1-5/64" high.
Effective in isolating vibrations from electronics such as amps, pre-amps, CD players, DAC's and power supplies.
From the manufacturer:
"PolyCrystal isolators are specifically designed for the resonance characteristics of electronics chassis, and are therefore ideally suited for use under all audio and video electronics, and power conditioning units. The Isolators are unparalleled in their ability to reduce the negative effects of resonance-induced coloration."
"The Isolator is created from PolyCrystal UHD (Ultra High Density) resin material for the ultimate in resonance damping. PolyCrystal is a composite made up of multiple inert materials, crushed to the sizes of their crystalline structures and embedded in a matrix. The result is a very high-density substance with extremely irregular boundaries between the interlaced crystals, which dissipates energy into heat. It is very dense and very heavy, and very effective at dissipating energy and resonance."
Price is $25.00 for the set of three + $5.00 for USPS Priority Shipping. Shipping to USA addresses only.
Payment accepted: Certified Check/MO or Paypal.
Please contact me if you have any questions. Thanks for your consideration.
« Last Edit: 17 Jan 2012, 08:25 pm by R Browne »
mikeeastman
Re: FS: PolyCrystal ISO-3 Isolator Cones (Set of 3)
« Reply #1 on: 17 Jan 2012, 01:38 am »
PM sent.
