0 Members and 1 Guest are viewing this topic. Read 12049 times.
... use mgalusha's neat FLAC -> WAV loader tool several threads below this one to expand before you play.
There seems to be a perception that Uncompressed Wave gives a superior sound
TAS is doing whole series of articles on computer audio In Feb 2011 issues TAS said " ... In preliminary tests, we have also found that FLAC files sound worse than their parent WAV files. Even when WAV is converted to FLAC and then back again to WAV, we have found the resulting secondary WAV files do no sound as good as the original."For reference quality - I'd say WAV is the way to go - otherwise FLAC is quite good for music enjoyment ...Cheers
To play devils advocate on both sides, first there is a way to analyze waveform and discern whether or not bit perfection is achieved after decoding. I saw a very smart analysis that showed the original WAV converted to FLAC, then both the original and FLAC files were decoded with one being 180 degrees out of phase from the other. The result, flat line which means that both conversions were 100% copies of each other. Other formats like AAC 256 or lower were compared to the original wav file and there ws a ton of noise, which translates into actual real world degradation of the copy compared to the original. That in a nut shell should convince anyone that the actual files are identical. Now whether the actual decoding process is done right... Who knows there!Now onto this idea that lossless means no loss at all. WRONG!!!!! Ever buy a stainless steel knife? StainLESS as in not as much? Ya I've taken stainLESS knives in the ocean and they were covered in rust as a result. Less does not mean 'proof' as in stainproof or lossproof there is ALWAYS the potential for loss. It is highly improbable that any transfer is 100% perfect, but most likely close enough. LossLESS as in to a lesser degree than the alternative aka mp3, AAC, or other lossy processes.
Not the same. It's a lossless file. It's like zipping the WAV file. You get the same thing out that you put in.
I don't know how to compare files bit for bit.
Are you telling me they would still be identical?
It IS the same! Though for different reasons. A stainless knife means less likely to stain. Similarly lossless means less likely to abberate data, though there are quite literally no gaurantees that said goal will be accomplished. Take a wav file and convert it to flac, then back to WAV then flac several thousand times then compare the final copy to the original file. Are you telling me they would still be identical?
I'm a newbie to music servers and am starting to rip all of my CDs to my HTPC running JRiver Media Center version 17, WASAPI event style, output 192khz, playing files from memory, via USB to Eastern Electric DAC Plus.So far I've ripped about 2 dozen CDs via FLAC level 5. There seems to be a perception that Uncompressed Wave gives a superior sound. I've tried ripping a few songs using both techniques, and not sure if I could convince myself if Wave is better. Sould I delete all of my FLAC files, and start over? I would love to get any opinions on how others have approached this situation.
