New caps for Acopian 5v power supply
0 Members and 1 Guest are viewing this topic. Read 1095 times.
rajacat
  • Washington State
« on: 15 Jan 2012, 06:39 pm »
My Acopian A5NT350 5v power supply that I use with a Bolder SB3 has been slowing losing output. I called the Acopian tech support and they said that since it's old (1993), it probably needs new caps. Since I'm going to install new caps I thought that I might as well give it an audiophile upgrade with better than stock caps. I'm looking for suggestions as to what brand of caps would be noticeably better than stock and fit into the case. BTW I'm not afraid of extending or rerouting leads. The pic shows the present caps.
25v 6800uf
50v 330uf
50v 150uf
63v 10uf
63v 2.2uf
50v 1 uf
I'm also looking for suggestions for any other easy upgrades.
..Roy
