Audio/Video Gear and Systems
The Discless Circle
toddbagwell
Multi-Room/Multi-Zone Audio Setup
0 Members and 1 Guest are viewing this topic. Read 1378 times.
bmk352
Newbie
15 Jan 2012, 05:31 pm »
I have been searching around and trying to figure out the best way to create a multi-room multi-zoned setup on the relatively inexpensive side. This rules out a Sonos or Squeezebox based solution as they are both too expensive to implement. Currently I am looking at using an alix3d3
http://www.pcengines.ch/alix3d3.htm
board as it supports POE and has an stereo audio output removing the need for at least one power plug at the output source. Ideally what I would like to be able to accomplish with this system is have 3 zones run by a board a piece pulling my music from my linux server. With these 3 zones I would like to be able to either play a different song in each zone or have a single song synced among the zones akin to Sonos.
I have played with MPD (music player daemon) which installs easily using the voyager-mpd linux install and works well for a single output at a time, but not multiple zones as far as I can tell.
Has anyone been able to accomplish something like this and are there instructions for diy?
bmk352
Newbie
Re: Multi-Room/Multi-Zone Audio Setup
4 Feb 2012, 11:44 pm »
Well here's what I have ended up doing:
Spun up a VM on my ESX server and installed Ubuntu Server 10.04 x64 base install and updates.
Installed Logitech Media Server using repository instructions
http://wiki.slimdevices.com/index.php/DebianPackage
Installed Voyage Linux on a spare laptop and compiled Squeezeslave from source
http://wiki.slimdevices.com/index.php/SqueezeSlave#Linux_build_instructions
Installed Voyage Linux on CF Card and setup Alix hardware
for use with X (alix3d3/alix1d):
changes in "/etc/inittab":
comment "T0:23:respawn:/sbin/getty –L ttyS0"
uncomment "#1:2345:respawn:/sbin/getty –L tty1"
changes in "/boot/grub/menu.lst":
"terminal serial" replace with "terminal console"
"kernel … console=ttyS0" replace with "… console=tty0"
comment "serial --speed=38400"
Copied compiled Squeezeslave from spare laptop to Alix hardware CF card and setup an automated startup daemon script.
Now I am running the Alix Squeezeslave over POE and have some speakers hooked up to the analog audio output.
With this hardware I have the option of adding a display later in case I want to have something shown
as well as adding a high quality USB DAC at a later date.
And the materials:
$130.60 Shipped ALIX 3d3
http://siliconkit.com/ocart/index.php?route=product/product&path=18&product_id=111
$11.85 Shipped 18V DC Adapter
http://www.pimfg.com/Product-Detail/PIPS-18-1A
$15.99 Shipped Sandisk Ultra 4GB CF Card
http://www.amazon.com/gp/product/B002T84DQI/ref=oh_o00_s00_i00_details
$3.99 Power Over Ethernet Injector
http://www.mini-box.com/s.nl/it.A/id.309/.f
$12.50 Indoor enclosure for ALIX.3 Boards
http://www.mini-box.com/ALIX-3-Enclosure
$0.98 I/O Bracket for Alix.3D3
http://www.mini-box.com/Bracket-for-Alix-3c2_2
$2.75 Shipping
$178.66 Total Cost
The Discless Circle
toddbagwell
