Open Baffle Mid Woofer Recommendation
0 Members and 1 Guest are viewing this topic. Read 2650 times.
vilbig
« on: 13 Jan 2012, 10:44 pm »
I want to try (as others have) to clone the Jamo R-909. I've pretty much decided on the Alpha 15's for the bottom, but am not sure which mid woofers will play down to 200 hz open baffle. I would appreciate any advice or links that might help.
matevana
Re: Open Baffle Mid Woofer Recommendation
« Reply #1 on: 14 Jan 2012, 12:24 am »
I like many of the Usher mid woofers. I especially like the 8137A in open back. It's an 8" kevlar driver with excellent low mids down to well  past 200 Hz.
vilbig
« Reply #2 on: 14 Jan 2012, 12:39 am »
That does look like an excellent driver. What was your crossover point to the tweeter? I only ask because I have read that an 8" can not cross very high.
