Glass audio rack, bad for sound?
0 Members and 1 Guest are viewing this topic. Read 3104 times.
mca
« on: 13 Jan 2012, 05:25 am »
My TV stand and audio rack for the last 10 years has been a Bell'O rack that uses glass shelves. I have heard stories that glass is not good to set equipment on. Can this potentially degrade the sound of my system? Short of replacing the rack is there anything I can do to help improve the sound?
JackD201
Re: Glass audio rack, bad for sound?
« Reply #1 on: 13 Jan 2012, 05:48 am »
Hi MCA,
Very hard to generalize, there are just too many kinds of glass. Equipment construction and their respective interactions with their platforms vary widely as well. I propose you try putting inexpensive stuff with very different densities like pieces of wood, cork, rubber pads, etc. between your components and your Bell Os. If you hear changes  experiment further. If you don't, it's one less thing to worry or bother about. Enjoy :)
Jack
decal
« Reply #2 on: 13 Jan 2012, 07:01 am »
Does it sound bad to you all of a sudden?
Elizabeth
« Reply #3 on: 13 Jan 2012, 12:33 pm »
I have three racks with glass shelves in metal rectangular section tubing.
I filled all the tubes with sand in all three racks.
One low long one is for the Plasma TV and video stuff.
Another low long one I have two turntables on, plus some stuff under.
And the third tall one my main audio stuff.
I use  butyl rubber bottle stoppers, and Sorbothane half domes.
The cheaper half domes are on Amazon. Same as the expensive 'audiophile' ones.
The sorbothane are softer, the Butyl a bit harder.
I also do some 'wedging' so the next up shelf is pressed on from below by rubber near the center or near the middle sides.
I find the rubber.sorbothane does all I need to stop the shelves from vibrating.
Even a cloth pad under the equipment would dampen the shelf. Even some rubber round things used to dampen sub cabinets, stuck under the center of the glass, or on top hidden under the components...
Butyl Chemical bottle stoppers, size 10 are great. Problem is they are getting to be hard to find on the internet.
I got mine from a local 'Science and Surplus', and have at least 40 of them!
Aside: if your glass shelves never bothered you, why worry what some 'know it all' claims?
To test if you can hear a difference, just use anything to dampen the shelving. Cloth, or whatever is at hand. (even your hands.. Can you 'feel' any vibration in the shelving when your system is at maximum listening level?)
tomytoons
« Reply #4 on: 13 Jan 2012, 02:43 pm »
I use all glass shelves here too.
I just put Herbie's Tender Feet under everything.
No Problem.
There are all kinds of Isolation devices out there and home made.
mca
« Reply #5 on: 13 Jan 2012, 06:01 pm »
I have been using the Sq products Isol-Pads for the last year of so. I wonder if the Herbies would work better?
mca
« Reply #6 on: 13 Jan 2012, 06:04 pm »
It's always sounded kinda bad. Just a bit of hardness up top I have never been able to tame. I just started wondering if it could possibly have anything to do with the glass shelves.
garywang304
« Reply #7 on: 22 Jan 2012, 10:25 am »
Try putting some metal pieces between your audio equipments and other electric devices on the shelf, in order to shield the possible incoming noises from other electronic devices.
