IKEA for your bass traps
0 Members and 1 Guest are viewing this topic. Read 7304 times.
pjchappy
« on: 13 Jan 2012, 12:18 am »
In a thread on a guitar forum, I came across a DIY bass trap using these IKEA products:  IVAR System (using side-units, posts, shelves (regular or corner) & braces).  Looks like a cheap and easy way (no cutting, etc.) to make a frame for your bass traps.  Just toss in rock wool or compressed fiberglass (details about the specific type can be found in other threads here.)  Cover the wool/fiberglass in your fabric of choice.  Of course, you can paint the frame to your desired color!
I will likely redo my bass traps with these.  Will look much better. :thumb:
Paul
« Last Edit: 13 Jan 2012, 03:46 am by pjchappy »
mca
Re: IKEA for your bass traps
« Reply #1 on: 13 Jan 2012, 12:33 am »
Your link takes me to IVAR products, so I am not exactly sure what you mean. Can you post the link to the thread on the guitar forum?
pjchappy
« Reply #2 on: 13 Jan 2012, 12:34 am »
Name corrected; link the same. :oops:
Here is the link to the guitar forum:  IKEA bass traps
Paul
mca
« Reply #3 on: 13 Jan 2012, 02:15 am »
Now I get it, pretty slick idea.
Letitroll98
  • Too loud is just right
« Reply #4 on: 13 Jan 2012, 03:24 am »
Great find PJ, will almost fit my rockwool panels.  There are some IVAR corner shelves (unavailable right now) that might be interesting as well for corner traps.
Rclark
« Reply #5 on: 13 Jan 2012, 03:46 am »
Fist pump  :thumb:
neekomax
« Reply #6 on: 13 Jan 2012, 04:18 am »
This I could do.  8)
Levi
« Reply #7 on: 13 Jan 2012, 04:20 am »
I have to give you credit.  Nice find!  :thumb:
Paul
nature boy
« Reply #8 on: 13 Jan 2012, 01:29 pm »
Cool, may give these a shot.
NB
Atlplasma
  • Just off the boat
« Reply #9 on: 13 Jan 2012, 02:34 pm »
I also like the use of Ultratouch Cotton instead of fiberglass. Has anyone tried Enguard insulation (http://enguardinsulation.com/)?
