0 Members and 1 Guest are viewing this topic. Read 11716 times.
Nice, did I read somewhere correctly that it's dual mono?
oh, one other interesting little story about my preamp adwentures - at the time, i spoke w/the owner of audio connection in verona nj; they are a dealer for rogue and audible illusions and cary. i was discussing my preamp angst - all these were under consideration, which is why i had called them. as i am basically a cheapskate, i also mentioned i would prefer used, and i was also considering the melos sha-gold-r, (one step below the ma333r, which i wasn't sure would fit in my budget). well, as soon as i mentioned the melos, the guy said "buy that one; it smokes anything else at its price point by cary, rogue or a/a." i asked him if he had any left-overs or used sha-gold-r's, and he said unfortunately not. he said they used to carry melos before they went under, and that there was else nothing like them. i was wery impressed that he'd be upfront w/me even tho it meant losing a possible sale.doug s.
I'm looking into it. How do you suppose it will sound with SS amps... for now?
how will it sound into s/s amps? a damn site better than any s/s preamp! i was using s/s amps when i first purchased my melos... and for those who believe i am a simple tube apologist, when i started my search for a tube preamp, i was using a linn kairn pre at the time. if i had to choose between the kairn and the rogue, it would be the kairn all the way. if i had to choose between the kairn and the cary slp98, it would be a toss-up - both did some things well, and left some things to be desired.the linn was exceptionally neutral, detailed, extended and accurate tonally. the rogue was none of these, and had an overblown bloated soundstage. the cary got soundstaging right at the expense of a slightly dark, less neutral less dynamic presentation. the melos equaled or exceeded everything the linn did right, while adding an exceptionally dimensional soundstage, w/o being overdone like the rogue.now, a caveat - recently, i decided to try an eva-2 remote ldr passive preamp between my melos and my amps. my melos, as well as being true dual-mono, had a mod that went so far as to have separate wolume pots for l/r channels. stock, there's a separate balance control and one wolume control that operates both pots. well, nothing more fun than having a remote to control two separate pots - not the most ergonomically friendly thing - they don't track exactly. this means i had to adjust the wolume for both pots, then fine-tune the balance by adjusting the left channel. yes, my melos remote is set up this way. so, wanting to keep my beloved melos, and make it more ergonomically friendly, i opted to try the (relatively inexpensive) eva-2, hoping it would do the trick, w/o exacting too much of a sonic penalty. i'd plug it in, max out the pots on the melos, and see (hear) what happened. lo & behold, the sound was even better! more dynamic and more detailed; i was floored! and my melos pre has an upgraded tube wolume pot which is ewen more transparent than the photentiometer pot - the first known implemention of ldr pots. so, while the melos is killer, and extremely dynamic & transparent, the latest ldr wolume pots are for real, and will make it sound even better.ymmv,doug s.
My only problem with it is me not wanting to get into a quagmire of repairs and upgrades with the Melos. Especially a defunct company. I haven't read too many good things about Melos Audio Restoration, if they're even still around. I just don't want to end up with a paperweight with glowing reviews.
m.a.r. is defunct; its owner wil guering passed away. but mark porzilli, the man behind melos, is going to be opening a restoration/repair/mod shop, as soon as his work on the nova physics memory 64 player slows down. all that said, in the 13 years i have owned my preamp, the only time it went anywhere was for mods. and, there are a few folks that know how to work on them. doug s.
I read that about Porzilli, but the last post I could find was from 2010.
keep us posted re: your thoughts, when you get it up & running...personally, i think you will be quite pleased. doug s.
