0 Members and 1 Guest are viewing this topic. Read 11682 times.
Maybe you could audition an AVA T8 with phonostage? Would be right around your $1,500 price point.
Unless you have a real need for an internal phono stage, why not go with a linestage and external phono pre. Get a little more isolation for the phono pre and allows you more flexibility as you get the itch down the road. And at $1500 for a tubed pre, I wouldn't think you'd be able to get an "exceptional phono stage." A decent, solid respectable one, yes. But you might be asking too much for an all-in-one tubed pre. I could be wrong though. Hope I am in fact...For a separtate tubed phono preamp, I'd take a look at the Quicksilver. Nice tubed phono (MM only) with a solid power supply. And very quiet in my system. $500 or so on the used market last time I checked.
w/a good tubed line stage, you will be fine w/using your s/s fono stage. simply move it when you need to rip winyl. and buy this:http://app.audiogon.com/listings/446606killer preamp, imo.doug s.
The answers to your needs are Dodd and Vista. How are you with a soldering iron (even if incompetent, Gary will usually fix your mistakes for cheap) and how efficient are your speakers? The Dodd buffer kit is universally acclaimed as top of the line equipment for around $350. Get a good tube for $100. Then add a Vista phono pre for another $350. Spend the rest on vinyl. Scott
