Floor Vibrations
0 Members and 1 Guest are viewing this topic. Read 2852 times.
Early B.
Floor Vibrations
« on: 9 Jan 2012, 06:40 am »
I understand that VMPS are designed NOT to use spikes. Got a question -- my VMPS Tower II SE speakers are resting on carpet and they aren't exactly stable. I can feel them vibrating while music is playing, and they wobble from the slightest touch. What do you guys recommend for stabilizing the speakers?
P.S. -- it's gotta be a WAF friendly solution.
Thanks.
Re: Floor Vibrations
« Reply #1 on: 10 Jan 2012, 12:14 am »
How is a speaker designed with or without spikes?
Conventional wisdom says spike on stable/rigid floors (like concrete) and float if on bouncy/soft floors (wooden joists/plywood).
I'd try hemispheric silicon door bumpers between the bottom of the speakers and a larger base that you could spike.
opnly bafld
« Reply #2 on: 10 Jan 2012, 01:07 am »
Because of the way the PR is loaded/coupled to the floor.
Brax
« Reply #3 on: 10 Jan 2012, 04:07 am »
Either add a larger base plate or replace the bottom base plate with a larger one. The original RM40 also had a narrow base plate, narrower than the speaker which made them a little unstable. The new style has a base plate as wide as the speaker itself. The wider the base plate the more stable the speaker, but the base plate must be securely attached to the speaker.
Early B.
« Reply #4 on: 10 Jan 2012, 04:32 am »
Good idea. I'll try that. Thanks.
Brax
« Reply #5 on: 10 Jan 2012, 12:08 pm »
Take a look at the picture sticky, there are pictures of both the old and  the new style.
Early B.
« Reply #6 on: 10 Jan 2012, 03:15 pm »
I like the outriggers on these LS9's.
Any ideas on how to make them?
rbbert
« Reply #7 on: 10 Jan 2012, 03:53 pm »
Wrong circle   :lol:
rollo
  • Rollo Audio Consulting -
« Reply #8 on: 10 Jan 2012, 04:56 pm »
  Herbies products work very well.  BTW is your room over a basement ? if so reinforce the floor with a plank and Lolly colums or 4x4.
charles
