0 Members and 1 Guest are viewing this topic. Read 4113 times.
How do diffusors affect the soundstage?
This article from Stece Deckert gives a quite good overview:http://www.decware.com/paper39.htm
Thanks for this link. Very straight forward. Looks like front/rear wall is their preference for Diffusion.Not sure which diffuser to use though. (thickness and #)
Proper diffusion will scatter both in space and in time. So the single specular reflection would then arrive at you from multiple places and at multiple times. The distance is really based on the lowest frequency that a diffuser will function. 5-5.5' is right on the edge of where the Q7D will function in terms of purely direct diffusion. Now, where we're working say up high in a room and primarily trying to minimize slap and flutter echo, the distance isn't as critical.The problem sitting too close is that there is simply not enough space for the waves to spread out in different directions and some pretty odd sounds can be heard very close to a diffuser. Bryan
