Sold: Modded Logitech squeezebox V3 SB3 Slim Devices
0 Members and 1 Guest are viewing this topic. Read 2832 times.
andychen
I have a modded squeezebox version 3 with a modded ELPAC WM220-1 power supply.
I followed this post to replace the SqueezeBox 3 SPDIF output with a BNC connector.
http://www.pinkfishmedia.net/forum/showthread.php?t=57212
I am including a Belden 1694A cable with Canare BNC terminations for this.
Asking $old
I modified the ELPAC WM220-1 power supply following this thread. I need to cut some wires, change the connector that would fit into SB3 and wrap them in electronic tape, so it appears to be broken, but it is actually working perfectly.
http://forums.slimdevices.com/showthread.php?t=33555
Asking $old
I used to have quite a few feedback at avs123 forum, also 396 (100% positive) ebay feedback (user ID: edeal2006), and tons of feedback at head-fi.org (user ID: andychen).
« Last Edit: 16 Jan 2012, 05:51 pm by andychen »
andychen
Major price drop.
Big Red Machine
Major deal!!!
andychen
To answer a few inquiries. I can sell these two separately.
SB3 with original power adapter: $110
ELPAC WM220-1: $40
mr_bill
Does the Elpac work on the Touch?
Big Red Machine
andychen
yes
Big Red Machine, many thanks. I did not even know that before, but if the touch and SB3's power adapters are the same or have the same output, I don't see why it wouldn't work. The Elpac is modified to output 5 V.
andychen
Re: FS: Modded Logitech squeezebox V3 SB3 Slim Devices
« Reply #7 on: 13 Jan 2012, 09:43 pm »
Final price drop.
