fuses for 3B legacy amp
0 Members and 1 Guest are viewing this topic. Read 2921 times.
vdubluv
« on: 2 Jan 2012, 08:36 pm »
New forum member wants to know if I need to replace fuses for an old 3B with fast or slow blow fuses? (4A 250V)  The filament in the replacement ones I bought at The Source are different than original so I am confused and uncertain.
RC
  • The Demo is Everything!
    • http://www.bryston.com
Re: fuses for 3B legacy amp
« Reply #1 on: 2 Jan 2012, 10:06 pm »
RC
Fast blow.
james
vdubluv
« Reply #2 on: 2 Jan 2012, 10:24 pm »
Thanks.  So I replaced it and it blew right away.  I notice on the back of the unit that there are labels saying "MID" and "HIGH" where the patch cords are.  Does this mean the previous owner made some modifications that are causing this problem?
« Reply #3 on: 2 Jan 2012, 10:31 pm »
Could be - if they are blowing right away then it probably means the output transistors are blown.
james
vdubluv
« Reply #4 on: 2 Jan 2012, 10:59 pm »
Thanks James. So what would you recommend as a next step for resolving the problem?
« Reply #5 on: 2 Jan 2012, 11:00 pm »
Where are you located?
James
vdubluv
« Reply #6 on: 2 Jan 2012, 11:13 pm »
I am near Sudbury Ontario
« Reply #7 on: 3 Jan 2012, 01:36 am »
Ok contact Mike Pickett at Bryston and arrange to send it in for repair. [email protected]
james
vdubluv
« Reply #8 on: 3 Jan 2012, 01:41 am »
Thanks James.  I sent him an email about the original fuse issue earlier today so I will contact him again about the latest developments.
vdubluv
« Reply #9 on: 13 Jan 2012, 06:34 am »
I have emailed and called to leave message for Mike Pickett and no response? Suggestions?
Mike Pickett
« Reply #10 on: 13 Jan 2012, 03:26 pm »
Sorry, missed your e-mails, but I've responded this morning...
Mike
SoundGame
« Reply #11 on: 13 Jan 2012, 03:43 pm »
Mike
Neat to see Mike on this forum - nice chest rug...  :lol:
Mike Pickett
« Reply #12 on: 13 Jan 2012, 05:45 pm »
Thanks!  I do try to drop in from time to time...
