Good Review on the BDP-1/BDA-1 for those who read French
0 Members and 1 Guest are viewing this topic. Read 1017 times.
  • The Demo is Everything!
    • http://www.bryston.com
Phil A
Re: Good Review on the BDP-1/BDA-1 for those who read French
« Reply #1 on: 29 Dec 2011, 09:45 pm »
You can also cheat :lol: and translate it - the conclusion says
"Conclusion and Recommendation
For the audiophile who already has a good converter
digital to analog, the BDP-1 represents a good alternative
Streamers in or if you prefer to music players
a network. Some of our competitors offer more cheaper
functions, but few have such a quality
of construction. The BDP-1 is not intended for access to thousands
radios available on the Internet, but in the version
its recent software, it gives you access to a dozen
positions of specially selected for quality by Bryston
files of their broadcast stream. The fact that the BDP-1 does
no mechanical parts or internal hard drive provides it
reliability and durability to any test. Whether you use
the coaxial BNC or plug AES / EBU to connect to a
DA converter, the results are as good through
one or the other of these connectors. Its implementation is easy,
handling very intuitive and the results are sound
high caliber. Anyway, here is what one might call a "combination
winning ."
