0 Members and 1 Guest are viewing this topic. Read 4576 times.
1. Click "Details" button under "Text services and input languages"2. Click "Add" button under "Installed services"3. Choose: "English (United States)" > "Keyboard - US"4. Remove the "English (UK)" item and any others you don't want5. Reboot
I assume you are not using webmail and are using Outlook Express or another local e-mail client program. Have you installed any other browsers in addition to Internet Explorer? If so, making another browser the default (Control Panel > Add/Remove Programs > Set Program Access and Defaults) and then switching back to Internet Explorer as the default sometimes solves the problem of e-mail hyperlinks not working. If that's not the case or if it still doesn't work, there are some other steps that you can try to fix it: http://email.about.com/od/outlooktips/qt/et_fix_links.htm (Windows 98/2000/XP section) Steve
I would give ie9, or better yet any one of chrome, firefox, or opera, a try and test if you still see the same behavior.
Internet Explorer 9 does not run on Windows XP. Steve
