Which SS amp should I dump?
0 Members and 1 Guest are viewing this topic. Read 2971 times.
thunderbrick
  • I'm just not right!
« on: 28 Dec 2011, 03:37 am »
I have put together a system for a buddy from my leftovers, and he'll take either my Hafler XL-280 or Parasound HCA 1000A.  Frankly I am not using either one right now, but both have done duty as a subwoofer amp for my Maggie 1.6 system.
Stupid question, but which one should I keep sitting on a shelf as a backup?  I have a much-loved Moscode 300 for the mains, and plan to buy 3.7s in about 18 months.
Hafler has a bit more power, but runs much warmer.
Thoughts?
'brick
Diamond Dog
Re: Which SS amp should I dump?
« Reply #1 on: 28 Dec 2011, 04:01 am »
Which one would you rather listen to if you had to insert it into your system, T ?
That's your keeper.
D.D.
bregez
« Reply #2 on: 28 Dec 2011, 04:45 am »
Dump the Parasound.
Hafler and Dynaco equipment always seems to hold some residual value even if it's not working.
No comment on which is a better amp.
Brad
srb
« Reply #3 on: 28 Dec 2011, 05:12 am »
Although the Hafler has a bit more power at 8 ohms (145W) versus the Parasound's 125W, they both output 200W at 4 ohms.
As a backup amp for Maggies, I would keep the Parasound due to its higher peak current (45A vs 18A) and slightly higher power supply capacitance (40,000 uF vs 30,000 uF).
decal
« Reply #4 on: 28 Dec 2011, 01:03 pm »
If you have used both of them and you know what they are capable of, why are you asking someone else what you should keep?  Am I missing something here?
« Reply #5 on: 28 Dec 2011, 01:40 pm »
How good of a friend are you?
If it's a toss up, I'd give the newbie the newer piece (it should last longer before age related issues kick in).
rollo
  • Rollo Audio Consulting -
« Reply #6 on: 28 Dec 2011, 03:49 pm »
  +1
charles
