0 Members and 1 Guest are viewing this topic. Read 29797 times.
One listens to a "system" rather individual drivers (hopefully! ).
When you start getting into more exotic cone materials, generally the more complex the enclosures becomes.
Beyond that, it would be planar and electrostatic speakers.
Bogus, bogus, bogus. Since when does an exotic cone material need a complex or sophisticated enclosure? Thiele/Small parameters apply equally well in either circumstance. Designers may employ sophisticated enclosures to heighten the sales appeal (increase the hype) but certainly don't need to! Don't forget that the OP was asking specifically about midrange drivers. Since when does a midrange driver need a sophisticated enclosure?Yes, they always do sound wonderful.
That being said, I can see reasons to go a bit extreme with a midrange enclosure as far as trying to eliminate most if not all of the internal reflections getting back to the rear of the driver. Something a little more than just an empty square box to house the driver in.
If you would like to learn more about midrange enclosures, I have a nice two part semi-technical series of articles that appeared in Speaker Builder magazine by Jim Moriyasu. I'm pretty sure it is copyrighted, so I cannot just post it here for everyone to look at, but I could send you the copies (pdf). PM me with an email address if you are interested.
I have a cylinder shaped mid enclosure filled with a fiber damping material. This works very well with the 5" driver ....
I'm a DIYer and that would be a lot of work. Besides it isn't very often that one manufacturer makes a series of nearly identical drivers out of three different cone materials. My experience with drivers is: If they sound the same, they measure the same. And if they measure the same, they sound the same.
Well, a bit late to the party, but I can think of one small manufacturer of drivers targeted to the DIY who makes versions of the same driver from at 2 different materials - Mark Fenlon - specifically the Alpair 6 in paper and metal.
Well, a bit late to the party, but I can think of one small manufacturer of drivers targeted to the DIY who makes versions of the same driver from at 2 different materials - Mark Fenlon - specifically the Alpair 6 in paper and metal. I've heard both and while the metal may be more precisely detailed (and have measurements to prove it - not that I personally care much about that part) I definitely prefer the paper for its more "organic" texture, and an ineffable "relaxed" quality.
Just swapped my poly cone jbl 104 mids for the older LE5 paper jobs. So far things are a more articulate and seem a bit faster. I will know more as the new cone kits break in .....
