0 Members and 1 Guest are viewing this topic. Read 29685 times.
I looked it up, HDA stands for "High Definition Aerogel"
Oh, sorry about that. I misunderstood you when you wrote "Knowledge of them hasn't been of any audible value to me. I never choose a driver based solely on its material."
From Ray Alden's "Speaker Building 201" in the first chapter under Timbre Quality-"If you compare two speakers systems that have a flat response and use a similar format with comparably sized drivers, little doubt that your final aural impression of them will be affected by the different materials they use." (The discussion goes further.)Food for thought...Tom
Yes, but I bet there are instances in which if you didn't have previous knowledge of the cone material, you wouldn't know for sure, or couldn't guess correctly.When you cannot see through the grille cloth.
Maybe there are diy folks lurking who could set up a comparison in the same box, same crossover of drivers with similar specs other than cone materials. Maybe time to check over at diyaudio, but man some of those threads are looong.
Æ, wow you have so extensive listening experience so far, would you please shorlist the most u impress with?i found that, aluminum cones from jordan and alpairs are good for hifi sound, but yet paper cones from beyma seems the most natural for voicing.cheershenry
Most speakers I have heard with these Scan-Speak paper cones sound really natural. Of course, other speaker elements (motor, suspension, etc.) and the design may have something to do with that beyond the cone material. Steve
