Tang Band W3-319SF 3" Full Range Driver
0 Members and 1 Guest are viewing this topic. Read 9272 times.
ebag4
« on: 23 Dec 2011, 11:07 pm »
Danny,
I picked up 4 of these from you last week.  I am wanting to build a pair of speakers for a small office in a nearfield (read as desktop) setting.  I have a couple of cabinet ideas I am considering but I was wondering if you gleaned enough information to make a recommendation as to what type of small speaker may work best with these drivers.
Ed
Danny Richie
Re: Tang Band W3-319SF 3" Full Range Driver
« Reply #1 on: 24 Dec 2011, 05:51 pm »
I am all out of these BTW.
I am making my kids some computer speakers out of them.
Each one needs .055 cubic feet of air space and a port that is 1/2" by 1/2".
jn316
« Reply #2 on: 24 Dec 2011, 06:05 pm »
Also, as Danny mentioned to me on the phone the other day, that port size is just a 1/2" hole drilled through the 1/2" material you build the box out of, if you decide to use that material thickness. Piece of cake!
ebag4
« Reply #3 on: 26 Dec 2011, 10:28 pm »
Danny,
If I wanted to use two of these drivers in a single enclosure and do the cap trick across the lower driver's terminals, what would this do to the port?  I am assuming I would simply double the size of the enclosure.
Ed
Danny Richie
« Reply #4 on: 27 Dec 2011, 12:02 am »
Danny,
Ed
That is exactly what I am doing.
Double the air space and the ports.
roymail
  • Roy in TX
« Reply #5 on: 27 Dec 2011, 12:17 am »
PM sent to Ed
Oscillate
« Reply #6 on: 27 Dec 2011, 12:39 am »
"...and a port that is 1/2" by 1/2""
So basically drilling a 1/2" hole through the enclosure (or two holes if two
drivers are used) is all that is required to properly port these?
ebag4
« Reply #7 on: 27 Dec 2011, 12:41 am »
Thanks Danny!
PM sent to Ed
Hi Roy, PM replied.
Best.
Ed
Peter J
  • Hmmmm
« Reply #8 on: 27 Dec 2011, 12:51 am »
Danny,
Ed
Can you elaborate on the cap trick?
ebag4
« Reply #9 on: 27 Dec 2011, 12:58 am »
Danny Richie
« Reply #10 on: 27 Dec 2011, 02:20 am »
Yep, that's the cap trick.
The LS-C uses this cap trick too.  :green:
Mr. Oczka
  • Audiophile in training
« Reply #11 on: 27 Dec 2011, 06:10 am »
This project sounds like an inexpensive chance for me to attempt to build some small speaker boxes!  My dream is to build a nice set of Danny's speakers, but my carpentry skills at this point are pretty limited.  This size box will give me an opportunity to practice using wood veneer.
Well, it's late, I can't sleep and my feeble brain is having difficulty with the box dimensions.  Danny says that the ideal size for this full range speaker is .055 cubic feet.  I'm coming up with 5 inches high by 4.8 inches  wide by 3.6 inches deep.  That seems really small even for this 3 inch driver.  Is my math correct?  What dimensions will you use?
Doubling up the drivers also interests me.  It will give me an opportunity to experiment with different size caps to hear the difference in sound clarity.  What size box would you build for 2 drivers?  I'm one to believe that two is always better than one.
Any guidance would be appreciated.
Tom
Æ
« Reply #12 on: 27 Dec 2011, 07:29 am »
Tom
According to the manufacturers specs, the Vas for that driver is only 1.68 liters or 0.059 cu.ft.
Danny Richie
« Reply #13 on: 27 Dec 2011, 02:44 pm »
The specs on the ones that I have may be a little different than the newer ones. Mine are an earlier version with twice the X-Max of the later ones.
Æ
« Reply #14 on: 27 Dec 2011, 06:36 pm »
I actually have some of the first generation W3-319 on hand, not really sure how much Xmax they have. I have a few different specs sheets. A print out from 2002 shows 0.5mm Xmax, but at another website it was listed at 1.0mm Xmax. Currently it is listed at 0.25 Xmax.
Danny Richie
« Reply #15 on: 28 Dec 2011, 01:25 am »
The version I had was the 1mm version.
ebag4
« Reply #16 on: 1 Jan 2012, 07:56 pm »
Danny,
What type of cap are you using for the lower drivers?  From what I can find film caps are getting physically large and expensive at this size.  Are you getting smaller values and paralleling them to get the desired value?
Edit:
Didn't see many at this value looking though the usual suspects, there are a few at Parts Express but I am not familiar with the brands.  I did find a Jantzen unit, it is nearly 2"x2.5", it can be found here:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=027-952&utm_source=googleps
Has anyone used a Jantzen cap, if so what did you think?  What are the brands you use at this value.
Ed
Danny Richie
« Reply #17 on: 1 Jan 2012, 08:52 pm »
I did quite a bit of testing with these drivers.
I did by-pass the lower woofer with a cap in the 47uF range for best results. But it still needed a baffle step compensation filter to flatten out the response. This made the sensitivity drop below 83db and the impedance high at an average of about 12 to 14 ohms.
Since my kids were using these as computer speakers, and driving them with a little T-amp that doesn't mind a 4 ohm load, I tried something else. I made it a 1.5 way design and paralleled the lower woofer and put a 1.5mH inductor in line with it. This flattened the impedance out and made it pretty smooth 4 ohm load and brought the sensitivity up to 92db.
They sound really good until you play anything wit a lot of bass, then they sound a little thin. But overall they sound great.
ebag4
« Reply #18 on: 1 Jan 2012, 09:15 pm »
Danny, thanks for this, much appreciated.  I have a pair of 1 mh coils in my junk box, how critical is this value, will these work?
Is this the correct wiring:
Best,
Ed
« Last Edit: 2 Jan 2012, 03:37 am by ebag4 »
Danny Richie
« Reply #19 on: 2 Jan 2012, 06:05 am »
Yep, that will do it and the 1 mH will get you close.
