I need help with Minimax Dac Plus Opamp replacement with LME49990- found it
0 Members and 1 Guest are viewing this topic. Read 1955 times.
schw06
I just received the opamps for U1, U2,U6, and U7 and I notice the orientation of the pins on the adapters from Cimarron are perpendicular to the pin orientation on the OEM's and I don't know which orientation is correct. Anyone out their that can help me!!!!
David
Addendum- I just found Doug Shroeder's explanation and got it figured out
Freo-1
So, don't forget to post your observations on the other thread.   8)
schw06
Thank you Big Red Machine!!!
