0 Members and 1 Guest are viewing this topic. Read 5841 times.
I'm considering changing my room around over Christmas. the dimensions aren't exact, but below is an approximation of my room. Red shows my existing setup, and green shows the proposed. 90, 180, and 270 degree rotations of my existing setup aren't possible.What are your thoughts on this? I have 3 GIK 242 and 4, GIK 244 panels that can be used. My main issue is that I'm able to hear a difference in the left and right speakers, most likely due to how close the left speaker is to the wall. The depth of the sound also seems to be limited due to the closeness of the speakers to the back wall. I appreciate any help or suggestions It's also a lot more work than it appears to be. I'll obviously have to re-route all my cables, but i'll also have to move my projector screen and build a new mount for the projector. I also have curtains running all around the room except where the screen is between the speakers. I'll have to move these around as well.
Nuance,If set up the speakers properly and mark the spike feet with painted tape. So it is much easier to set it up next time. It is very hassle at first but after doing it for awhile I seem like to know the position by head.
^ Dialing in a system in a room of this type can come down to inches, so moving the speakers constantly would probably be a hassle, taking a very critical eye and ear to get things dialed in properly Good idea, though.Coke,You already said this, but just to be 100% sure: you absolutely cannot change the layout to having the speakers on the South or West wall (based on the diagram)?
