VR-4 upgrade to VR-5/6 status
0 Members and 1 Guest are viewing this topic. Read 2603 times.
lax11
« on: 21 Dec 2011, 02:26 am »
Hello,
I was wondering if anyone has had their VR-4 speakers upgraded to VR-5/6 status? I spoke with Albert about this and plan to do it in January. If you could share your thoughts and impressions that would be great. :D
JackD201
Re: VR-4 upgrade to VR-5/6 status
« Reply #1 on: 22 Dec 2011, 08:53 am »
I've owned a whole lot of VS speakers but I've only had one upgrade done. The others, I just kept on going up the ladder from GenIII HSEs and topping off at VR-9s.
It was the 9s that were upgraded to Mk2 status. If my experience is anything to go by, I would say the upgrade packages are a no brainer. Go for it!
JBNY
« Reply #2 on: 4 Jan 2012, 03:38 pm »
I sent my VR4.5 to Albert to be upgraded. He is upgrading them to the new VR-44 though. I should get them back next week. I can post some more info when I receive them and break them in.
-Joe
cthulu the clown
« Reply #3 on: 7 Jan 2012, 12:01 am »
I had it done when it was first announced (I think I have the second pair he did, guessing from the S/N). Well, it's hard to compare w/o both versions side by side, especially after some time elapsed. The upgraded speaker is really damn amazing, I can say that! I actually prefer it to his newer stuff, which I drove out there to audition.  After the upgrade the 4's bass is definitely tighter and far more crisp; more realistic for common things like kick drums.  The base 4 (at least early ones) had incredible bass extension but were a bit soft on bass transient impacts.  That's totally fixed; the bass is as close to perfect as I've heard anywhere.  There might be a touch less extreme LF extension afterwards, but it's very hard to say (ample bass down so low few recordings have much info that low).  Mid/highs are incredible, and of course the bass is simply awesome.  I've yet to find anything I like as much as the upgraded 4's for even 4x more $, even after all this time. I wish they were smaller, ofc, but then that's part of how they do the full range so well while still being relatively efficient and natural sounding. If you're considering his new ones go hear them first.  If you like the sound of the 4,  as I do, the upgrade is great.  Now if only I could get my damn cat to stop pulling the stuffing out thru the bass port...and eating it.
es347
  • ..I've got my eye on you...which one you say?
« Reply #4 on: 8 Jan 2012, 03:23 am »
Perhaps you should stuff the dacron in your kitty's rear port.  That may very well tighten things up a bit.
farshad
« Reply #5 on: 8 Jan 2012, 08:50 am »
what is the price of the upgrade from vr4 to 5/6?
ceedee
    • Musical Reality
« Reply #6 on: 8 Jan 2012, 08:35 pm »
Hello Farshad,
Just send a mail with your question to:
[email protected]
Albert or Damon will answer your Q, some day, I know they will.
Cor
