0 Members and 1 Guest are viewing this topic. Read 8994 times.
Just be aware that the optical out is still limited to 24/96 even though Apple says otherwise. I've only been able to get higher than 24/96 out through the USB and FireWire ports.
My guess would be that the move to the Sandy Bridge architecture in the 2011 Mac Mini is responsible for the improved jitter numbers.
I have been looking at optical lately as i was told that my usb/spdif converter was limiting resolution. I never really thought the Toslink mini on my Mac Mini was a viable option due to jitter in that port.Having said that, I can't stand the idea of a usb cable to usb/spdif converter to a spdif cable... yuk! So, I'm going to give the SillFlex cable a shot and see what happens. Sure would be a more elegant hook up and save me about $600.Has anybody heard anything about the reduced jitter coming out of the new Mini Toslink ports on the '011 Mac Mini's, as outlined in the below thread/link? I currently have a '09 mini that I was going to open up and put in an SSD and 8gigs of RAM. I was wondering if it would be possible to upgrade the Toslink to the new lower jitter versions. Or maybe it's lower jitter due to other factors other than the port itself?? [hurl]http://forum.audiogon.com/cgi-bin/fr.pl?ddgtl&1323911432&read&keyw&zzjitter+of+new+mac+mini+optical+line+out+improved[/url]
Toslink on the other hand is like the lowest form of SPDIF known to man. It has the highest jitter typically from 3300pS to 6800pS and has the worst error rate of any known SPDIF tranport type.USB with async on the other hand is capable of going to 192K (Toslink though some are capable of 192K is only specd to 96K) with really low jitter when done with async protocol and done correctly. Even if you use off the shelf crap like some companies do you can get below 100pS of jitter really easily. In most cases with some of the stuff I have designed and tested it's below 50pS and some even below 10pS. You could never get close to that with SPDIF as it is always moving and the receiver would be required to match that speed. Which means it cannot use a fixed oscillator for that. Anything that is not fixed has tons of jitter... hey that is what jitter is right? the movement of a clock from a fixed state.
A quote from Gordon Rankin recently on the Asylum. A USB DAC and USB Converter manufacturer so take it FWIW.
Just more food for thought. The proof is in the pudd......sound. It's all about what sounds best to you.
The actual original phrase is "the proof of the pudding is in the eating." NOT "the proof is in the pudding." So in this case, you could just say "the proof of the pudding is in the listening."
