Cheap Dedicated Transport: Little Dot, or...
0 Members and 1 Guest are viewing this topic. Read 5437 times.
murf
  • Friends don't let friends apex early
« on: 19 Dec 2011, 05:36 pm »
Hello Audio Experts!
  I would like to try a dedicated transport to feed into my W4S dac-1(w/ dac-2 cap mods).  I'm tired of getting decent used cdp's that break.  Thus I am wary of getting great but old transports (ie: Esoteric, Theta, Cal Audio Delta, PS Lambda, etc).  I would prefer to spend less than $500., if possible!
  The Little Dot cdp-1 seems to stand alone at the low end.  Then maybe the HIFIDIY CDM12 kit, and then the Lite Audio LT-ONE which is over my limit (probably).  Any others?
  So, will the little dot cdp-1 sound better as a transport than say, the Marantz sa8003 or Berendsen cdp2? Ditto for the other above transports?   :scratch:
TIA!  Murf
timind
  • permanent vacation
Re: Cheap Dedicated Transport: Little Dot, or...
« Reply #1 on: 19 Dec 2011, 11:30 pm »
Up your budget a bit and get a Mac Mini. Rip your cds in your choice to AIFF with XLD and you won't have to worry about the transport.
SET Man
« Reply #2 on: 19 Dec 2011, 11:39 pm »
Hey!
   Currently I'm using Sony SCD-C200ES 5 CD/SACD changer as my transport. Works fine for me. But I have to admit that I'm also curious about the Little Dot transport also. :D
Take care,
Buddy :thumb:
« Reply #3 on: 19 Dec 2011, 11:41 pm »
Non-computer options:
Oppo 93: $499, very good sound quality, will play nearly any format.
Really cheap:
Used, look for Oppo 970/971 (former Stereophile rated).
eclein
« Reply #4 on: 20 Dec 2011, 12:52 am »
See if Virtue Audio has any Piano M1's left...built like tanks but sound exqusite...I got one and will probably never need a new CD player ever.....seriously....Virtueaudio.com
They have a circle here...check it out
murf
« Reply #5 on: 20 Dec 2011, 02:59 pm »
Yes, but...
   I have a good dac, so I was wondering if a dedicated transport at 1/2 the price would be better than a transport in a cd player where I'm paying half the price towards the dac that is included.  And I'm not into ripping my music yet.
   If I could go new & still get quality sound that would be best.  Getting a used transport, whether stand alone or in a cdp seems like buying a replaceable (sometimes available) part.
Murf   8)
« Last Edit: 20 Dec 2011, 06:15 pm by murf »
tull skull
  • I can't send hare in search of anything!
« Reply #6 on: 20 Dec 2011, 05:14 pm »
Please forgive me if this is a stupid idea or if it is just not relevant anymore but I remember an article from several years ago about using a stand alone computer disc reader. I think it was at the Positive Feedback site and the author was quite impressed. I remember you had to use some type of disc cassette for this particular reader, and perhaps that is why he got good results. Does anyone remember that article?
srb
« Reply #7 on: 20 Dec 2011, 05:43 pm »
Pure CD external readers don't exist anymore, and are at a minimum CD/DVD readers without a laser optimized for CD audio playback.  I would also expect that anyone who is using the device for playback of their music library would want transport controls at a minimum which are usually absent from these devices, and probably wouldn't mind having remote control either.
