Other Stuff
Archived Manufacturer Circles
Music Reference
RM-5 gain settings
RM-5 gain settings
0 Members and 1 Guest are viewing this topic. Read 2623 times.
EC Bailey
RM-5 gain settings
18 Dec 2011, 09:58 pm »
Can anyone post the DIP switch setting options (gain selection,) and/or provide general guidance as to which gain to choose? TIA.
rbwalt
Re: RM-5 gain settings
19 Dec 2011, 03:47 pm »
i thought the dip setting chart was in the inside the pre. a e-mail to roger should do the trick. it might take him a bit to get back to you. he is very busy. in the latter version of the 5's he did away with the DIP switches.
i looked through all of my old MR literature but nothing.
r.
EC Bailey
Reply #2 on:
19 Dec 2011, 04:48 pm »
D'oh, yes, I found the tag inside the unit. Could not figure out how to edit my post. Would still appreciate any suggestions about how to choose an appropriate setting.
Photon46
Reply #3 on:
19 Dec 2011, 06:03 pm »
I find using the least gain possible results in the most transparent sound. When last using my RM5, I used 9 db. of gain.
Other Stuff
Music Reference
RM-5 gain settings
